Lowering/Performance Springs
Updated August 4, 2006
4-WHEEL LOWERING KITS
1995-99 Chevrolet Monte Carlo/Lumina.
1988-96 Cutlass Supreme, Regal, and Grand Prix; 90-94 Lumina; 97 Cutlass Supreme
FRONT PERFORMANCE LOWERING SPRINGS (All)
Lowering the front is easy because these cars use conventional coils on the front.
LOWERING THE REAR (All EXCEPT 95+ Monte Carlo/Lumina)
Since the rear end uses a fiberglass rear monoleaf spring that runs transversely from left to right, you are unlikely to find any lowering kits to lower all 4 corners of your car. Manufacturers of coil springs aren't usually in the leaf spring business and vice versa. That means you will have to buy a rear lowering spring from another company.
Things that won't work: The rear monoleaf cannot be flipped upside-down. With no load, it is curved in a "C" shape. To flip it upside down would permanently bottom the suspension. It would be exactly the same to remove the spring completely.
Copyright ©2000 The W-Body Page
