'89 Cutlass DIS
93CutlassSupreme
You can get some fun diagnostics though, press DEST, RESET, then enter mileage 8192.
what will happen?
It just shows a diagnostic screen that shows VSS status (H or High, L for low), fuel level in percentage, park lamps on or off, dimmer level, etc.
Here's my wiring... all soldered and heat shrunk, then taped.
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
  • 93CutlassSupreme
    30
  • GutlessSupreme
    16
  • GnatGoSplat
    12
  • 99RegalGS
    3
did you hear that shit, Tony? Shawn doesn't like our wiring skills!!!!!!!
:lol:
Heat shrink tubing.
It's a rubbery tubing that shrinks when heat is applied. Cut off a piece, slide it on the wire, then twist the 2 pieces of wire together, solder, then slide the heat shrink tube over the soldered joint. Use a lighter to heat it up, and it'll shrink to a tight vinyl covering that's as durable as wire insulation and it won't come off. I use it on all my wiring as it's weather-tight (prevents oxidation) and very strong. Don't have to worry about it unraveling in the future.
:lol:
pff, now I REALLY wish I had more detailed pics of the harness for my windows/locks before I put it in the car :lol: probably would've had heart failure.
Heat shrink tubing.
oooo.. sounds spiffy. sell it at radio shack and the like I assume?
how accurate is the Fuel Econ function?
driving 35 mph at about 1500 rpm, the Instant Fuel Econ says 40-41 mpg. that can't be right.
I'd believe that on instant fuel econ...1500rpm doesn't use much gas...
:lol:
Hahah! Yeah, I've been told I'm kinda particular about stuff.
I once spent almost an hour futzing around with the trunk alignment on the 94 because of a 1/16" difference in the gap between one side and the other.
Heat shrink tubing.
Yeah, Radio Shack has some. Harbor Freight has a variety pack of different size and colors. I prefer the more pliable 3M stuff. I had to order that from Digi-Key.
what's the minumum coolant temp it will display?
whenever i start the engine cold, the dis reads 73* F and then warms up from there.
come to think of it, my coolant temp gauge is the same. from a cold start, it jumps up a little bit instead of starting from the low peg. they have to get the signal from the same place so that makes me wonder...
I wonder if thats how hot the initial spark is, or maybe when it first starts the initial combusting, it's like 73*.
It goes well below 73. I don't remember the lowest I've seen it though.
hmm. wonder why that's the lowest mine will display
I bet its that warm because it's summer time. Wait until it starts getting real cold out...
damnit!!!!! don't talk about cold weather!!!!!!
anyways, i hope that's it. i don't feel like draining coolant and changing temp sensors
Holy crap I didn't know that! Any other weird tricks with the info center? Almost makes me want to go out to the car and try it.
Would a grand prix dic work in a cutlass? I like its looks better, and my dash dosen't come down lower that the climate control. I would rather switch to bucket seats with a floor shifter.
Grand Prix DIC should work, although the Cutlass one is much better as far as what it can do. GP DIC only adds a compass, albeit a rather large one.
I am going to put one in my Cutty as soon as it arrives from Davis.....
you can get that piece from a yard cheap as hell
my dash was flat there, i just added the larger panel to fit the dis
i paid $10
it takes 5 minutes to install too.
