93CutlassSupreme Posted August 11, 2004 Report Posted August 11, 2004 this weekend i'll be changing out front rotors (again) before, i always used a drill and a wire wheel to grind all the rust off the hubs. any quicker way to do this? also, is their a easily avaiable commerical solution or rustproffing or something that will actually slow the rust down? i've been using Mercury Marine's Corrosion Guard the last 2 or 3 times i did brakes, but it really hasn't done a whole lot. Quote
DiscoStudd Posted August 11, 2004 Report Posted August 11, 2004 I always coat the hubs and the mounting surface of the rotors with anti-sieze. Coat the front face of the rotor around the lugs and the lugs themselves with it, too. Next time you do a brake job, you'll be glad you did! Oh yeah, and coat the caliper bracket mounting bolts too... Quote
93CutlassSupreme Posted August 11, 2004 Author Report Posted August 11, 2004 thanks for the idea i was thinking of trying some of that rust removal gel that i've seen in stores Quote
Brian P Posted August 11, 2004 Report Posted August 11, 2004 thanks for the idea i was thinking of trying some of that rust removal gel that i've seen in stores naval jelly? Quote
93CutlassSupreme Posted August 11, 2004 Author Report Posted August 11, 2004 thanks for the idea i was thinking of trying some of that rust removal gel that i've seen in stores naval jelly? thats it. i've also seen a few rust removal sprays. i'm looking for a quicker way to remove the rust, so i don't have to sit there all day with a drill grinding it off Quote
stockgp Posted August 12, 2004 Report Posted August 12, 2004 after you remove the rust, get some zinc chromate paint and paint the hubs. they'll never rust again Quote
93CutlassSupreme Posted August 12, 2004 Author Report Posted August 12, 2004 thanks for the rust prevention tips, but anyone know a quick way to remove rust that is already on the hub? Quote
Brian P Posted August 12, 2004 Report Posted August 12, 2004 quick would be the naval jelly, as long as the rust isn't awful. Quote
93CutlassSupreme Posted August 12, 2004 Author Report Posted August 12, 2004 i guess i'll try that Quote
