Guest RedCutlassSL Posted December 19, 2002 Report Posted December 19, 2002 could anyone tell me what the replacement number is for the hood light. also where can i get a new fuse for the horn. its the fuse thats located in the black box in under the hood. and how can i check to make sure the fluid pump works, cuz no fluid comes out Quote
Guest RedCutlassSL Posted December 19, 2002 Report Posted December 19, 2002 fluid comes out now, nevermind Quote
paulo57509 Posted December 19, 2002 Report Posted December 19, 2002 could anyone tell me what the replacement number is for the hood light. also where can i get a new fuse for the horn. its the fuse thats located in the black box in under the hood. and how can i check to make sure the fluid pump works, cuz no fluid comes out Underhood bulb = 561 Quote
Guest RedCutlassSL Posted December 20, 2002 Report Posted December 20, 2002 yeah well i replaced, still no light comes on. grr. is there a fuse on that? Quote
paulo57509 Posted December 20, 2002 Report Posted December 20, 2002 yeah well i replaced, still no light comes on. grr. is there a fuse on that? Probably, but I would think that this light wouldn't have its own fuse and would be fused along with some other lights. Unplug the electrical connector from the lamp housing and probe it with a volt meter. There should be 12 volts there. If not, you need to trace the circuit backwards from there. An electrical schematic will help. If there is 12 volts at the connector, the problem might be with the lamp housing. I would imagine that there is some kind of mercury or "tilt" switch in there that might be bad. Quote
Guest Posted December 20, 2002 Report Posted December 20, 2002 also, my ends had corroded pretty badly. I had to sand it down real good, and it worked fine after that. Taylor Quote
88Intl Posted December 21, 2002 Report Posted December 21, 2002 BTW, on my truck I put a crimp-on bullet connector inline with the ground (not hot) side of the hood light. This can be disconnected so as not to drain the battery when leaving the hood open a long time. Quote
