Leaking moon roof
My moon roof developed a leak. Can it be adjusted to seal tighter? Also where are the drains for it?
Sounds like it needs a new rubber seal. The drains are in the front corners of the drip channel. I'm not too sure if the dealer would service a moonroof, so look up "Sunroofs" in the Yellow Pages and try to find a sunroof specialist to take it to...
Car custom shops should also be able to help with getting seals.
Does it have seals in the back to? If not does that mean I have to park nose down on the incline?
I assume you're asking if it has drain tubes in the back. No drain tubes in back, but the channels are slanted slightly towards the front to drain the water away when you're parked level. The stock "astroroofs" are engineered quite well and were designed with the expectation that the gasket/seal would leak, hence the drain system.
If your headliner is still in tact, then you can probably assume your moonroof is draining properly.
