GnatGoSplat Posted August 8, 2004 Report Posted August 8, 2004 I got the Flex-A-Form rear spring yesterday and installed it today. It actually arrived on Thursday, but George sent it to the address on my check instead of the one on the letter and order form I included with payment. That happened to be my old address where luckily, my brother-in-law lives there so he just brought it by my house yesterday. Anyway, here's the pics: Before lowering, I measured 29-3/4" from wheel well to floor. Other side was about the same. After jacking up the car, setting it on jackstands, and removing the wheel, the next step is disconnecting one trailing arm. That sumbitch was TIGHT and killed my $20 Harbor Freight 12V impact wrench. I had to improvise. Overspray? I don't see no stinkin' overspray! Removing the jack pad and spring retainers were easy. Using the spring compressor was also easy. The spring came right out, nothing to it. Here's a comparison of the stock spring on top and Flex-A-Form spring on the bottom. I swear the pic looked centered on my camera's LCD! Both rubber pads on my OEM spring had worn through, no wonder the rear suspension made so much racket! Here's a top view. The FAF spring is is noticeably narrower. I hope it's strong enough to last! The FAF spring goes in without even needing the spring compressor. I had to kind of wrestle with the bolts and spring retainers since the FAF spring isn't quite to perfect OEM tolerances, but I expected that. Only difficulty came when it was time to get the trailing arm bolt back in. For that, I had to get Penny's help. Me kicking on the knuckle while she attempted to feed the bolt through. Once I got that back together, I had to use my jack again to help me torque it to 192 ft-lbs. Here's a pic of the finished product after a spin around the block to seat the spring. The rear is still noticeably higher than the front with ST springs. Well damn, George claimed a 2-3" lowering, but it only dropped the rear 1.25". Awww fudge, I measured that I need another 1.25" drop to match the front exactly. Well, now I don't know what to do if I want my car level. I'm thinking maybe adding 94-96 aux springs back on will help. I removed and chucked mine long ago because they didn't work with the 94+ rear brake conversion. At the same time, I also installed the KYB rear struts. That raised the car's rear end about 3/4". I don't know whether it was removing the aux springs or installing the KYB's (which have a very strong gas charge) was responsible for the increase. If the aux springs, maybe putting some back on will drop it an additional 3/4". If the difference between front and rear was around 1/2", I probably wouldn't have been disappointed because it wouldn't be so obvious, but the difference is 1.25". I don't really want to get coilovers, but I wonder if that's the only way to get a perfect rear drop? Hmmmm... what to do? Quote
Brian P Posted August 8, 2004 Report Posted August 8, 2004 Shawn did you drive the car around a little so the spring seats itself in? I imagine it'd need about 10-20 miles of city style driving before you can get a true height. Also, BOTH a stiff shock and having no aux springs will raise it up, though the aux springs change it very little. Quote
loominaz34 Posted August 8, 2004 Report Posted August 8, 2004 That is one NICE looking cutty. dayum. Hey gnat, where do you live? Quote
GnatGoSplat Posted August 8, 2004 Author Report Posted August 8, 2004 Shawn did you drive the car around a little so the spring seats itself in? I imagine it'd need about 10-20 miles of city style driving before you can get a true height. Also, BOTH a stiff shock and having no aux springs will raise it up, though the aux springs change it very little. I actually didn't drive it anymore than a mile. Everything is expired on it since I've been working on it off and on, but I think I'm ready to get it insured, inspected, registered, and back on the road this week. Hopefully a few miles of break-in will lower it a bit. I'm not sure if I want to go to a softer OEM-style strut or not. Aux springs are no problem, but don't they soften the ride? Then again, that might not be a bad idea with 18"s. That is one NICE looking cutty. dayum. Hey gnat, where do you live? Thanks man, this body style is my favorite W. I live in the state next to yours, but still pretty far. Quote
musthavemuzk Posted August 8, 2004 Report Posted August 8, 2004 now out of curiousity does wheel size play any part in how far the drop is? it does help though Monty Quote
digitaloutsider Posted August 8, 2004 Report Posted August 8, 2004 Damn your car looks great, man.. Give it time to adjust itself. Quote
GnatGoSplat Posted August 8, 2004 Author Report Posted August 8, 2004 now out of curiousity does wheel size play any part in how far the drop is? it does help though Diameter of the tire will affect the car's height, but it won't affect the change in height. Quote
god910 Posted August 9, 2004 Report Posted August 9, 2004 What you need Shawn is a 1" MDF box for 2 twelves in the trunk. That'll get ya and extra 1/2" Quote
GnatGoSplat Posted August 9, 2004 Author Report Posted August 9, 2004 I already have 2 12's in the trunk. 8) Quote
Guest TurboSedan Posted August 9, 2004 Report Posted August 9, 2004 that sucks hopefully the rear end settles after you put some miles on it. Quote
Brian P Posted August 9, 2004 Report Posted August 9, 2004 now out of curiousity does wheel size play any part in how far the drop is? it does help though Diameter of the tire will affect the car's height, but it won't affect the change in height. Yes, H, not delta H Quote
Robby1870 Posted August 9, 2004 Report Posted August 9, 2004 now out of curiousity does wheel size play any part in how far the drop is? it does help though Diameter of the tire will affect the car's height, but it won't affect the change in height. Yes, H, not delta H Now your speaking my engineering language Quote
bluegp Posted August 9, 2004 Report Posted August 9, 2004 I like your idea there in the 2nd pic - using the jack for more wrench turning power! Why didn't I ever think of that? Quote
Canada Posted August 9, 2004 Report Posted August 9, 2004 Put 200 miles on it.............I'll bet it'll drop enough 0.5" by then. Quote
White93z34 Posted August 9, 2004 Report Posted August 9, 2004 i've changed rear ends in RWD cars before and trust me after a full day of there being no load on the rear leafs the car sits higher for a day or so after the job. Quote
GnatGoSplat Posted August 9, 2004 Author Report Posted August 9, 2004 Put 200 miles on it.............I'll bet it'll drop enough 0.5" by then. 0.5"? I need 1.25" more drop out of it! The Flex-A-Form spring might work for some people if all they need is a 1.25" drop. I think that's all the drop the ST front springs offer. Only problem was the ass end of my Cutlass rode 1.25" higher in the rear even before I dropped the front, so after dropping the front, it needed lowered 2.5" in the rear. I guess I'd better see what George at Flex-A-Form will do because the car looks better, but not $300 better. Quote
1990 Lumina Euro Coupe Posted August 9, 2004 Report Posted August 9, 2004 gnatgosplat wrote: Does every W-Body member have one of these jacks?? :shock: Quote
rudefyet Posted August 9, 2004 Report Posted August 9, 2004 gnatgosplat wrote: Does every W-Body member have one of these jacks?? :shock: nope...i dont...mines red...made by a company that starts with an M Quote
cutlsp Posted August 9, 2004 Report Posted August 9, 2004 gnatgosplat wrote: Does every W-Body member have one of these jacks?? :shock: I can't afford a nice shiny jack like that i'm poor Quote
cutlsp Posted August 9, 2004 Report Posted August 9, 2004 that sucks can i have your old leaf spring? :oops: i know mine on my white cutlass is wearing out :? Quote
dsgrntld187 Posted August 9, 2004 Report Posted August 9, 2004 Nope, I have a Craftsman 3 ton SUV jack. Anyways, Just let the car settle itself in. Put something big in the back, like uh.. bricks or something. That'll help it Quote
SigEpCutlass Posted August 9, 2004 Report Posted August 9, 2004 wow maybe I should buy my grandma's 88 cutty international and make it look as pimp as shawns...cause minus mods it's identical Quote
loominaz34 Posted August 9, 2004 Report Posted August 9, 2004 I have that jack, AND the matching jackstands. I dont think either have been used. Quote
White93z34 Posted August 9, 2004 Report Posted August 9, 2004 i have a jack like that and the matching jackstands however those are holding the back or is it front of the diplomat up in the air currently :shock: Quote
jeremy Posted August 9, 2004 Report Posted August 9, 2004 I too have that jack and a couple other hydrolic ones too.... ...anyway it does look better, but you are right, $300 is a decent amount to spend and not get the results you were promised.... Quote
