loud door
godofthunder
Recently, my door has been getting reallly loud. Like squeaking when I close the door.
Can I just put some heavy duty lube on the hinges, or does it need to be taken off and set back on a bit better?
Im going in for an oilchange and tire rotation/ballance (think thats actually why my car rides like shit) next week. My exhaust should be bent in the next month or so. Id like to get the door done to while im there with my dad.
Thanks yall
jon
tighten the bolts holding the hinges to the door jamb
mine were loose and made all kinds of noise
like a cheap old car dragging door noise?
Ill do that tommrow...see what it does...i think I did something like that once before on our old lumina.
yeah kind of like that. mine made a cracking noise.
try it. it can't hurt
When my passenger door started doing this, I tightened the bolts a bit, and greased that bitch up! Bling bling motherfucks!
On my 88 the doors are naturally hanging a bit low, so the hinges make some noise. I WD'd it, and then put on some thicker grease now its quite.
