manualturbo Posted December 18, 2002 Report Posted December 18, 2002 hey guys, i was wondering, what kind uff would i need to put the battery in the trunk? the biggest reason is b/c i want to make an intake setup, but theres just now enough room.basically im looking for how much wire, what gauge u suggest,what kinda connectors and stuff like that(especially the stuff from the alternator-unless that routes to the secondary post by the fuel pump relay) thanks guys, mitch 90 tgp 5 sp Quote
Guest Anonymous Posted December 19, 2002 Report Posted December 19, 2002 Most auto parts stores should have or be able to get battery relocation kits. Quote
Intlcutlass Posted December 19, 2002 Report Posted December 19, 2002 I "was" going to do the same thing.... I even bought 40' of welding cable, and started a custom sealed battery box, complete with a vent leading to the outside of the car (when a battery is charging it's a good idea to give it some kind of ventelation) I was going to remove the battery, remove the old air intake. Then cut a circular hole in the metal behind the headlight just big enough to use a k&n inverted cone filter. If you do this I would like to see it completed. I gave up on mine, cause that was part of my 3.1 turbo swap project for my cutlass. I still used the air filter though. I hacked the crap out of the old air box, so that a I could use the stock mounting holes/location. Anyone want 40' of welding cable. It's better than the cable you would get in a batt relocation kit. It has thicker insulation, and is more flexable. I have already cut it in half so it's really 2 x 20' lengths. Quote
