dsgrntld187 Posted August 3, 2004 Report Posted August 3, 2004 Ok I've seen those manifold wraps that supposedly lower the engine bay temperature. Is that BS or is it true? If it's true, would wrapping the crossover by my short arm intake help at all? You'd think it would if it lowers the temp at all. Quote
digitaloutsider Posted August 3, 2004 Report Posted August 3, 2004 Not totally sure about the header wrap, but I know for a fact that coated headers DRAMATICALLY drop the temperature in the engine bay. Damn things are cool to the touch. Quote
White93z34 Posted August 3, 2004 Report Posted August 3, 2004 hell yeah manifolds get upto like a bajilion degrees in a very little time. Quote
dsgrntld187 Posted August 3, 2004 Author Report Posted August 3, 2004 Do they sell coated headers/manifolds for the 3100? Quote
Justin Posted August 3, 2004 Report Posted August 3, 2004 Headers and manifolds aren't quite the same thing here though. Headers are thin wall steel, and give off more heat. Manifolds are thick cast, and give off less heat. It'll still help some I would suppose though. Quote
KING JOKER Posted August 4, 2004 Report Posted August 4, 2004 i have heard both sides of the story but i am gonna try it within the next few days so i will share my results when i get the time to wrap them up Quote
dsgrntld187 Posted August 4, 2004 Author Report Posted August 4, 2004 If it works lemme know, I'll wrap the front one up and the radiator tubes also. Maybe this will be a good enough CAI for now. Quote
gp90se Posted August 4, 2004 Report Posted August 4, 2004 Pros: lower under hood temp (u can wrap the manifolds and crossover, turbo if u got 1) Cons: manifolds/crossover will get HOTTER and could crack, any salt/dirt will corrode faster when wrapped Quote
brian89gp Posted August 6, 2004 Report Posted August 6, 2004 coating- cools it off a noticable amount, acts as a real good paint so it doesn't rust as a bonus wrap- cools it off 10x better then ceramic coating, but it WILL trap moisture and rust out whatever is underneath. Quote
no1kicker Posted August 6, 2004 Report Posted August 6, 2004 So would this work to keep heat out? Like on my upper intercooler pipe, which is right above the turbo and gets hot as hell. I'm assuming cooling this pipe might make a slight difference. Quote
KING JOKER Posted August 7, 2004 Report Posted August 7, 2004 the cooler the air the better the turbo performs Quote
gp90se Posted August 7, 2004 Report Posted August 7, 2004 the cooler the air the better the turbo performs thank you king obvious, the colder the air on any motor the better. Greg, yes wrapping the upper intake pipe in good insolation will help, we have done it on a few cars, doubt u will feel the HP increase, but it might help to run slightly higher boost levels when racing. Quote
conley3.1 Posted August 7, 2004 Report Posted August 7, 2004 Header wrap usually voids the warranties on aftermarket headers, so if that gives you a clue. I'm sure it couldn't really hurt a manifold though, not easily. Maybe replace it every 6 mos? EDIT> Actually after thinking about that, I doubt you could even remove header wrap. It's probably sticky as hell and baked on after 6 mos of like 500* temperatures. Quote
