From GNTTYPE.org
CODE 31
Trouble Code 31 indicates that the Wastegate Solenoid may not be functioning correctly. The wastegate solenoid is controlled by a Pulse Width Modulated (PWM) signal from the ECM. The ECM controls turbo boost by varying the PWM waveform (duty cycle) to the wastegate. The wastegate responds by bleeding off exhaust pressure upstream of the turbine, thus controlling boost pressure.
The conditions for setting this code are:
the ECM is commanding a solenoid duty cycle of between 5% and 94%, and
no electrical feedback is being received from the solenoid, and
the above conditions are met for 2 seconds.
Typical causes for this code include:
1) Poor or corroded connections between the ECM and the wastegate solenoid
2) Open or shorted solenoid
3) Defective, sticking or maladjusted wastegate linkage
4) Defective ECM
Ensure correct operation of other engine subsystems, including but not limited to the TPS and MAF sensors and check the wastegate actuation hardware.
And from troublecodes.net
31 High turbo pressure (87 - 88 )
Jimsperformance.com (whoever the hell THAT guys is :lol: )
31 Manifold Absolute Pressure (MAP) Sensor - signal voltage is low
OR Fuel injector
OR CAM diagnostic
OR Governor Malfunction
OR Wastegate overboost
OR Wastegate Eletrical Signal - open or shorted to ground
:bonk:
Thanks! That was the only noe i couldnt find, but right before I did the diagnosis I did overboost the car, so that explains that one(vacuum line poped off wastegate).
