ABS code 62
I'm getting an ABS code 62 - "low accululator precharge" - on my 1991 Buick Regal GS with the 3.8L. I've been told that all i need to do is replace the accumulator. The master cylinder on this thing is designed with the ABS unit attached. It basically looks like one BIG master cylinder with all the wires and tubes comming off of it. Can anyone tell me where the accumulator is and how to replace it? Is it relatively easy, or should I just send it to my mechanic to replace? Thanks for the help.
Curlybandit
its the thing with the big plug in connector on the master clyindar. They are not cheep.
Just incase I don't want to waste my time with the accumulator, does anyone know if it is possible to convert this vehicle from the ABS system to the non-ABS system? Is it as easy as replacing the ABS master cylinder with the non-ABS one? I've heard that it can be done. Thanks for the help.
Curlybandit
