Simple question...
What should my battery voltage read with my car turned off?
I'm assuming 12 volts, but see a lot of "12.5" volts mentioned across the web.
Also, my battery is an Optima Red Top dry cell, does outside air temperature dramatically effect the voltage? Or should it?
For example, if it's 80 degrees, should the voltage be higher than if it's 20 degrees?(I know this is true with regular acid batteries)
Thanks!! :)
A battery is considered GOOD as long as it remains anwhere between 11, and higher volts at rest. Most normal batterys are anywhere from 12 to 13 volts at rest.
Taylor
