Royal Purple Trans Fluid
I just did a trans fluid change and decided to use Royal Purple.
Has anyone used this? I do feel it shifting smoother(maybe i am just feeling this coz i paid a lot :roll: )
Feedback pls
was done on a camaro on horse power tv suppose to work really well so i guess ur not imagining it
yes synthetic tranny will help you shuft MUCH better and run cooler, meaning it will last longer. worth the investemnt IMO
  • 2 weeks later...
just some feedback
had the synthetic trans fluid now for more then a week and i really feel the improvement.
before i used to shift from 1-2 very rough... now it has smoothened out but i still feel it shifting at times (some cars you dont even feel the shift from 1-2, 2-3, 3-4). the car has been shifting smoothly in higher gears.
i would say this royal purple is pretty good, have not tried other syunthetic oil though.
how does the fluid change how the car shifts? is it just me?
my cutty runs synthetic amsoil tranny fluid. it works great, but it's still not as smooth as i'd like it to be. I would like not to feel any shifts, but that's probably not possible...
I may have to see about putting this in my GP, I know that tranny could shift a lot smother then it does now.
Royal Purple works great. a cheaper alternative is to use the regualar style fluid and add a bottle of Lucas Trans. Treatment. It will shift better than a new tranny. I used it in my car and it removed a shift shudder problem i had.
How are you guys changing out ATF?
I'm curious as to what the synthetic stuff does when it mixes with the ATF thats currently in the transmission. You aren't supposed to mix synthetic and dino engine oil.........I'm curious if that shouldn't apply here too.
where'd you hear that from? you know what Valvoline Durablend is? a mix of regular and synthetic oil. you know what high-mileage oils are? a mix of regular and synthetic additatives.
looks to me like oil companies mix synthetic and dino oil all the time.
Yeah......and b;ended oils suck dick...........look at any online comparison (other than one made by blended companies)........and you'll see they are worse than Fram filters.
blended companies?
i guess ALL oils made by Vavoline and Castrol, among almost every other oil brand name, must suck dick, because, in addition to convential and fully synthetic oils, they also make a blend.
:roll: :skep:
