jamhoney Posted July 30, 2004 Report Posted July 30, 2004 I am planning on swapping in some L67 36lbers for my L32 31lbers in a couple days. Is there anyone that knows what steps generally need to be taken to accomplish this safely? I have asked on clubshitty.com already. Quote
Aaron Posted July 30, 2004 Report Posted July 30, 2004 Yah, actually while I try and think of osmething assholish to say. Make sure you clamp the line or bleed the pressure, otherwise you'll have gas(premium I hope) EVERYTWHERE. And you thoguht L67s lit on fire easy on their own.......try having gas all over them Now the assholish part. Yah, plug the right wire into the right injector Quote
manitcor Posted July 30, 2004 Report Posted July 30, 2004 wont be to hard man, just a stright swap, its an L36 BTW :oops: Dont forget http://www.mymonte.com for L36 questions, we got some good guys over there ;-) (yes I know shameless plug) Quote
jamhoney Posted July 30, 2004 Author Report Posted July 30, 2004 L36? No I am swapping in L67 injectors.(36lbers) I have an L32(31lbers). Am I mistaken about the rate of flow on the L67 injectors? Quote
manitcor Posted July 31, 2004 Report Posted July 31, 2004 L36? No I am swapping in L67 injectors.(36lbers) I have an L32(31lbers). Am I mistaken about the rate of flow on the L67 injectors? Ahh based on your body style you have a genIII 3.8, am I mistaken or isnt that still the L36??? Sorry man now Im confused. Even so as long as you swapping from the same year L67 you shouldnt have a problem. I THINK the only thing that has changed in the past few years if the connector to the harness. I know this is an easy swap on the older L36/L67 but im not up on the new 3rd gens and Im really more of a 60v block guy. Quote
jamhoney Posted July 31, 2004 Author Report Posted July 31, 2004 Sorry about the confusion. I was just looking for a general answer as to what needs to be done to safely remove the injectors. I think these are the engine codes: L32 = 2004 GTP L26 = 2004 GT L67 = 97-03 GTP L36 = 97-03 GT Quote
god910 Posted July 31, 2004 Report Posted July 31, 2004 Ahh based on your body style you have a genIII 3.8, am I mistaken or isnt that still the L36??? Sorry man now Im confused. Even so as long as you swapping from the same year L67 you shouldnt have a problem. I THINK the only thing that has changed in the past few years if the connector to the harness. I know this is an easy swap on the older L36/L67 but im not up on the new 3rd gens and Im really more of a 60v block guy. Yeah, the Gen. III S/C is an L32. I didn't realize the injecters were so damn small though. Quote
jamhoney Posted July 31, 2004 Author Report Posted July 31, 2004 Yeah it is wierd they dropped from 36 to 31lbers. They also changed the fuel system so the pump is in the tank and the pressure is at a constant 60psi. Quote
god910 Posted July 31, 2004 Report Posted July 31, 2004 Yeah it is wierd they dropped from 36 to 31lbers. They also changed the fuel system so the pump is in the tank and the pressure is at a constant 60psi. How is the pump in tank any different? The extra pressure explains some of the drop in rating. Quote
no1kicker Posted July 31, 2004 Report Posted July 31, 2004 I would think it would be pretty straight forward. I would pull the fuel pump relay, and let it run til it dies to releive pressure. Also get new O-rings. I would replace the fuel filter too if you haven't already. Is there any tuning required for bigger injectors? Just curious as I am 70% sure my next car will be a newer GTP. Quote
jamhoney Posted July 31, 2004 Author Report Posted July 31, 2004 You just need an AFC 1.1 or 2.0. Quote
manitcor Posted July 31, 2004 Report Posted July 31, 2004 yeah now that I know what your asking, its really stright forward, just be careful when pulling them out of the lower intake and make sure that the o-ring doesnt fall down into the engine, that makes for a bad day Quote
Aaron Posted August 2, 2004 Report Posted August 2, 2004 I think these are the engine codes:L32 = 2004 GTP L26 = 2004 GT L67 = 97-03 GTP L36 = 97-03 GT Who cares they all suck Just messin , but you should get a fire extemguisher on your A pillar.... Quote
mfewtrail Posted August 3, 2004 Report Posted August 3, 2004 Yeah it is wierd they dropped from 36 to 31lbers. They also changed the fuel system so the pump is in the tank and the pressure is at a constant 60psi. Is the fuel pressure regulator on the 04 in the tank also?(returnless fuel system?) Just wondering... Quote
jamhoney Posted August 3, 2004 Author Report Posted August 3, 2004 Yes that is conveniently mounted in the tank. Some have suggested converting it to a boost dependant system. Quote
weasle_13 Posted August 4, 2004 Report Posted August 4, 2004 WHAT WOULD BE A LOGICAL SWAP FOR A 3100'S INJECTORS Quote
manitcor Posted August 4, 2004 Report Posted August 4, 2004 WHAT WOULD BE A LOGICAL SWAP FOR A 3100'S INJECTORS 22.5lb injectors from the 3400 but only if you have a 96 or higher unless you convert to ODBII TURN YOUR CAPS LOCKS OFF Quote
weasle_13 Posted August 4, 2004 Report Posted August 4, 2004 Sorry, I am at work, and have to write all internal memos in caps. How hard is it to convert it to odbII Quote
manitcor Posted August 4, 2004 Report Posted August 4, 2004 Sorry, I am at work, and have to write all internal memos in caps. How hard is it to convert it to odbII not too hard provided you have a 3100/4t60 or DOHC/4t60, t65 engine trans combination. Im upgrading to ODBII myself along with a trans upgrade but to go to ODBII you dont need to change the trans: http://www.mymonte.com/shwmessage.aspx?ForumID=2&MessageID=179095 Quote
manitcor Posted August 4, 2004 Report Posted August 4, 2004 It is a 4t60-E in a 1995 GM3100 Same combo I have/had you can do the upgrade just like im doing. Moving to a 4t65 trans is optional. Without the trans upgrade your parts cars will be 96-99 prefferably same model but not completly neccassary. Quote
weasle_13 Posted August 5, 2004 Report Posted August 5, 2004 WHAT ARE THE ADVANTAGES TO THE 4t65 TRANSMISSION? ALSO, IS THERE A MANUAL SWAP I CAN DO? Quote
manitcor Posted August 5, 2004 Report Posted August 5, 2004 WHAT ARE THE ADVANTAGES TO THE 4t65 TRANSMISSION? ALSO, IS THERE A MANUAL SWAP I CAN DO? the t65 is a stronger tranny and has become the GM standard on all 00+ W-cars Its a close relative to the t60 however can handle more power and is less prone to the famos 75k destruction most seem to expierence. Theres also a much larger aftermarket if you want to build a trans that can take some serious power. There are manual options but the info is scarce and its very rarely done. I've yet to see someone install a manual in 1.5 or 2nd Gen W-body unless that car had a manual option in the first place. Quote
weasle_13 Posted August 5, 2004 Report Posted August 5, 2004 Theres a first for everything, and my car usually has to be the guennea pig of ideas. Quote
manitcor Posted August 5, 2004 Report Posted August 5, 2004 Theres a first for everything, and my car usually has to be the guennea pig of ideas. hehe I know what you mean, my car has been known for alot of firsts, too bad not all of them have been successful. :oops: Quote
