gp90se Posted July 30, 2004 Report Posted July 30, 2004 i swear this car doesnt want me to drive it. Let it sit for 3 days, put a new battery into it and now I have no spark, wonderful. Swapped the coil/modual/ecu/checked the plugs. I really REALLY dont want to do the crank angle sensor, so anything else I can test, or a way 2 test the crank sensor before im stuck doing this thing? something stupid im missing mabey? -Jeff Quote
Guest Anonymous Posted July 30, 2004 Report Posted July 30, 2004 Here, this should help. http://img.photobucket.com/albums/v293/redturbo90/CPS.bmp Quote
R Dubya Posted July 30, 2004 Report Posted July 30, 2004 The crank sensor really isn't that bad to change.. just jack it up and make sure to use jack stands so it doesn't fall on you and crush you. 7 or 8 mm bolt to remove it from the block, and disconnect the harness, then pull it out slowly. There is a chance that it will break when you pull it out, so be careful and gentle. It's only like $15 or $20 from Advance. Are you sure that ignition module is ok? Quote
gp90se Posted July 30, 2004 Author Report Posted July 30, 2004 as easy as that sounds, the car is parked on dirt, so I really cant jack it up safely. Is there a resister I can put into the plug just to move the car 6 feet? -Jeff Quote
Guest Anonymous Posted July 30, 2004 Report Posted July 30, 2004 Don't you have anyone that can help you push it? Quote
gp90se Posted July 31, 2004 Author Report Posted July 31, 2004 lol slightly uphill in the mud, when we (4 of us, me being the smallest) attempted 2 push it to do the fuel pump, it barely moved, ended up playing tractor pull with my blazer attached to the cradle 2 move it. Quote
god910 Posted July 31, 2004 Report Posted July 31, 2004 Damnit man, get that car outta the mud. Quote
gp90se Posted July 31, 2004 Author Report Posted July 31, 2004 LOL id like 2 have it on the road, but it wants no part of it. you wanna come fix it ill be glad 2 keep it outta the mud. Quote
no1kicker Posted July 31, 2004 Report Posted July 31, 2004 That car needs to be running soon! If you need a hand, I'm free this Sunday and most weekends. Quote
gp90se Posted July 31, 2004 Author Report Posted July 31, 2004 I had it running 3 days ago, now this :x but Ill let ya know bout sunday. Ive gotta go work on my boys 94 z28 480 rwh superchaged camaro, but I do wanna get it running again, so Ill let ya know. Quote
gp90se Posted July 31, 2004 Author Report Posted July 31, 2004 goin off topic, but o well. he has more ponys then he knows what 2 do with behind his 6 speed, in 4th gear he can knock the rear end out and light em up, and were prolly swapping a smaller pully onto the procharger in the next couple of months. makes me wanan go back 2 the rwd v8 f-body lifestyle..... stay stong, TGP wont let me down, we'll, thats what I keep tellin myself Quote
gp90se Posted July 31, 2004 Author Report Posted July 31, 2004 Anyone have the GM part # for the crank sensor? EDIT: 10456555 Quote
