Access through the firewall
I'm trying to run a wire through the firewall, I can't seem to locate any wire inlets, just plugs that are bolted to the firewall. I can't get my hands down there to undo anything.
Any recomendations how to run the wire from the battery to the trunk, any advise greatly appreciated.
-Jeromy
What size wire are we talking about? If large I would say make your own hole :wink: and make sure to use the proper grommet. If it's small we used to just run it through an existing plug, such as the speedo cable or throttle cable hole. If small enough it should fit through w/ the existing cable/wire in there.
Below and to the left of the abs there is a factory hole for standard shift cars. If you have an automatic the hole is empty. Thats the hole most guys use.
Jud
