What does the turbo mount to? Is it rigidly mounted? Or is it suspended from the exhaust pipes? Thank you
Guest TurboSedan
it is rigidly mounted. the bottom of the crossover flange has 2 extra bolt holes...this is where the crossover pipe bolts to the automatic transmission shield. if you're using a 5-speed (like i am) you'll need to fabricate a turbo support bracket.
I am thinking that if it were on a flexable mount it would absorb the heat expansion of the crossover tube (I would like to build one with no flex joints to worry about.)
