skiiirt Posted July 25, 2004 Report Posted July 25, 2004 I've had a problem with my car starting since day 1. The car takes on average about 5 -6 seconds of cranking to start. If I stop; turn the car off and crank, it will fire up immediately. Sometimes it will fire as soon as i start cranking. I was advised to let the computer boot (wait 10 seconds) before start. That doesnt work. Sometimes when I turn the key I get a click and no start, but if I turn the car off and back on it works fine. The crank sensor was just replaced with the engine. The battery is brand new any ideas? Also I dont have an accessory function. Like I cant turn the key backwards to get the tape player on. Could it perhaps be the actual ignition that is misfunctioning? Quote
digitaloutsider Posted July 25, 2004 Report Posted July 25, 2004 Also I dont have an accessory function. Like I cant turn the key backwards to get the tape player on. Are you using a factory/GM original key or a duplicate from say a hardware store? Quote
93CutlassSupreme Posted July 25, 2004 Report Posted July 25, 2004 Also I dont have an accessory function. Like I cant turn the key backwards to get the tape player on. Are you using a factory/GM original key or a duplicate from say a hardware store? if a duplicate key is cut properly that shouldn't matter if it is cut poorly then i could see problems Quote
THe_DeTAiL3R Posted July 25, 2004 Report Posted July 25, 2004 My sister's Sunfire wasn't starting until the second time you turn the key. It would just *chug chug die*, and then start up fine. I put some fuel injector cleaner and it started up perfect. Quote
5speedz34 Posted July 25, 2004 Report Posted July 25, 2004 IDK...IMO I think the 3.4's take longer to crank. Quote
skiiirt Posted July 25, 2004 Author Report Posted July 25, 2004 Its an original GM Key. Wether or not its a duplicate GM key I don't know. Also, on a side note. I want to install some form of remote start. I don't want to be causing any damage to the car because the crank time is rather long and having a starter try with no success. (i've heard horror stories about remote starters). Anyone have any info on this. Maybe some advice as to what to get. I want an alarm system, more than willing to buy an expensive system that comes with a starter as well. Just don't want to waste my money on just an alarm, seeing as I only have my car to protect, no sound system Quote
