What all should i replace with head gaskets ?
I am getting ready to let my buddy from toyota replace my head gaskets
because of lost compresion and loosing water.Since i will be that deep
in the motor,what can i replace to get performance.I think ill have him
port and polish but i do not know.Just give me some thoughts and opinions
on the subject.
Guest Anonymous
yeah some one else reply, i have to do the gaskets as well!
Guest TurboSedan
new head bolts are a MUST. run a tap down thru the head bolt holes and spray them out with Brakleen. you'll obviously have to replace the lower intake manifold gaskets as well as the plenum gaskets. replace the oil pump drive o-ring while you have it apart. i'd resurface the heads and get new valve seals installed as well as a valve job.
Guest TurboSedan
Mine as well just replace the 3.4 at that point!
pretty sure he doesn't have the 3.4 considering his username....
Guest Anonymous
He may not but im asking the same question...i better face it my 3.4 is shot it needs to go
