i have no clue where it is supposed to be connected to..looks like the one end is connected to the brake lines or something im not to sure, in the pics i put an arrow by the hose..hope you dont mind the huge ass pics.
http://www.oznium.com/gallery/photos/thumb/4209/cutty-oldsmobile-cutlass-supreme
http://www.oznium.com/gallery/photos/thumb/4211/cutty-oldsmobile-cutlass-supreme
and this last one shows where the other end is connected..
http://www.oznium.com/gallery/photos/thumb/4214/cutty-oldsmobile-cutlass-supreme
any clues??
Canister purge solenoid. Look on the back of the plenum for a little black box with a red/blue 3 wire harness attached to it. There will also be a vacuum line attached to it.
alrite ill have to take a look, and it must have been like that for awhile
ok well i still can figure out where it goes, there is a hose connected where brian said so i have no clue and it must have been sitting like this for awhile now..and when the car is running it doesnt sound like there is air or anything coming out of it.
well did you locate the canister purge solenoid? It has two ports- one for the big vacuum line that goes from it to the throttle body (the 3 vac lines going to the TB- follow the FATTEST one) there should be another port right next to it- that's where this other tube is supposed to go. You may not be able to see it clearly without extra light or even tilting the engine. BTW your pics no workie.
