GrandPrix34 Posted July 11, 2004 Report Posted July 11, 2004 Mainly the #6 plug wire, when I pull the plug from the spark plug when the engine is on, in the dark I can see the wire arcing to the other wires and at the coil tower. Actually, when I pull any wires, they seem to leak current to anything near...can this truly be faulty wires or is it at the Coil where the problem is? Cracked coil maybe? Quote
WhiteOut Posted July 11, 2004 Report Posted July 11, 2004 Simply detaching the spark plug end of the wire should never cause arching. If you had removed the plug and left it attached to the wire then arching would occur, but an unattached boot should not cause arching. I'd say replace the wires. Quote
DOHCRagtopguy Posted July 11, 2004 Report Posted July 11, 2004 A sure symptom of wires that need replacing, I concur. Quote
GrandPrix34 Posted July 11, 2004 Author Report Posted July 11, 2004 damn, just bought these Taylor 8mm wires...damn it! But is it possible its because of the way the DIS is designed? Quote
Canada Posted July 11, 2004 Report Posted July 11, 2004 But is it possible its because of the way the DIS is designed? No. Quote
WhiteOut Posted July 11, 2004 Report Posted July 11, 2004 The wire alone should never, as in NEVER EVER, cause an ark. If there were a plug attached to the wire then yes, you would see arching between the plug and the engine or other surrounding metal parts, but thats not the case from what I read. If your wires are arching then something is seriously wrong with them. Quote
GrandPrix34 Posted July 12, 2004 Author Report Posted July 12, 2004 when attached to the plug they dont leak though...only when pulled. What gives? Can this affect me at high RPM's, say a 1/4 mile run? I got a meet the 16th so I am doing as much as possible to the car. Quote
WhiteOut Posted July 12, 2004 Report Posted July 12, 2004 If they leak unattached, they leak when attached. Its just that the plug provides less resistance so most of the electricity goes throught the plug. Try removing other wires to see if they do the same thing. I think you'll find that they don't. And if thats the case you need to replace the wires again, it may not be dire, but it is a good idea. Quote
GrandPrix34 Posted July 12, 2004 Author Report Posted July 12, 2004 so here's another question: Will that result in a lower 1/4 time by alot or have not much effect at all? Quote
WhiteOut Posted July 12, 2004 Report Posted July 12, 2004 so here's another question: Will that result in a lower 1/4 time by alot or have not much effect at all? Its hard to say with out testing the electrical system to see how much current is leaking. If you don't notice a problem when the car is running though its probably having a negligable effect on things. Quote
