bighonkhonk Posted July 9, 2004 Report Posted July 9, 2004 ok, i think that my cooling system needs to be bled. So where in hell is the bleeder screw at? BTW all that needs to be done is pull out the screw and wait until coolant comes out then put it back right? Quote
Guest TurboSedan Posted July 9, 2004 Report Posted July 9, 2004 i usually start the car (completely cold) with no radiator cap and let it run until it starts bubbling out. then i put the cap on and bleed it. Quote
THe_DeTAiL3R Posted July 9, 2004 Report Posted July 9, 2004 BTW all that needs to be done is pull out the screw and wait until coolant comes out then put it back right? Yes. The bleeder screw is right on top of the thermostat housing. You can also use the bolts from the t-stat housing (thats what I did, cause my bleeder screw is corroded/not working :? ) Quote
bighonkhonk Posted July 9, 2004 Author Report Posted July 9, 2004 Thanks that should make things easier Quote
