Maverick Posted July 8, 2004 Report Posted July 8, 2004 First the anti-lock, now this one. What the fuck. Ideas/suggestions? I don't even use the ebrake anymore since it stoped setting properly. Quote
Guest TurboSedan Posted July 8, 2004 Report Posted July 8, 2004 try pulling on the e-brake release handle and pull *up* on the lever. Quote
runt Posted July 9, 2004 Report Posted July 9, 2004 Doesn't the Brake light come on if there isn't enough fluid? Also, check your fuses for the brakes, tails and turns. I had my car do this when the brake lights didn't come on when the pedal was pushed. Quote
ismellrealbad Posted July 9, 2004 Report Posted July 9, 2004 that was my problem. i had low fluid so the light would always come on and go off Quote
DiscoStudd Posted July 9, 2004 Report Posted July 9, 2004 I know if you're having problems with the ABS, the BRAKE light will sometimes light along with the ABS light. Can't say for sure why, but maybe you need to have the Brake Control Module scanned if you're already having ABS problems... Quote
bluegp Posted July 9, 2004 Report Posted July 9, 2004 First the anti-lock, now this one. What the fuck. Ideas/suggestions? I don't even use the ebrake anymore since it stoped setting properly. Check the switch mounted on the parking brake pedal - pull the connector off & see if the light goes out. Mine broke causing the brake light to stay on. Quote
Speckkial Posted July 9, 2004 Report Posted July 9, 2004 sticking rear calipers perhaps...? I don't think sticking rear calipers are the problem. My rear caliper was frozen and my e-brake light never came on. Quote
jeremy Posted July 9, 2004 Report Posted July 9, 2004 I would bet that low fluid is at minimum part of the problem.... Quote
