mfewtrail Posted July 8, 2004 Report Posted July 8, 2004 Does anyone have these? If so, please post them! Thanks. Quote
99RegalGS Posted July 9, 2004 Report Posted July 9, 2004 From my Chiltons manual. Elevation: Intake .2500 Exhaust .2550 That's all it has. :? Quote
rudefyet Posted July 9, 2004 Report Posted July 9, 2004 pulled these out of a repair manual...hope they're what you need Bearing Journal Diameter 1.785 to 1.786 inches (45.339 to 45.364mm) Bearing Oil Clearance 0.0005 to 0.0035 inches (0.013 to 0.089mm) Lobe Lift Intake 0.250 inch (6.35 mm) Exshaust 0.255 inch (6.48 mm) Quote
mfewtrail Posted July 9, 2004 Author Report Posted July 9, 2004 Thanks! I'll probably be measuring the actual specs on a series I camshaft soon myself also. Thinking about putting a custom cam along w/ some other things into a series I engine later(NA buildup). Quote
dbtk2 Posted July 10, 2004 Report Posted July 10, 2004 There are a few people on the bonneville forum that have all the specs for the cam, like lift, lsa, duration, etc.... But, its basically almost the same as the Series II cam...the series II cam is like .255/.258, just a little bigger than series I. I think it has a couple more degrees of duration too. Shawn Quote
