Speckkial Posted July 7, 2004 Report Posted July 7, 2004 Has anyone ever had to replace their water pump? My car makes this sounds, like when you are accelerating, you can hear the engine picking up but when you come to a stop it sounds like it's dying. I took it to a mechanic a couple of weeks back and he told me that it was probably my water pump. Has anyone ever had this problem and was it costly? Quote
GnatGoSplat Posted July 7, 2004 Report Posted July 7, 2004 It's not particularly costly nor difficult to replace. I think all the 60-degree V6's use the same water pump, and I believe a Delco branded one cost me $16 from O'Reilly Auto Parts and maybe $4 for a tube of RTV silicone. They're pretty easy to replace. I don't have any idea how much it would cost to pay someone to replace it though. Do you plan to pay someone or do you plan to do it yourself? Quote
Speckkial Posted July 7, 2004 Author Report Posted July 7, 2004 I know someone that can do it. I just didn't know how cheap the actual part is. But you had this problem yourself? Did your car make these sounds? Quote
GnatGoSplat Posted July 7, 2004 Report Posted July 7, 2004 I'm not sure what the sound you describes really sounds like, but I've had a bad water pump make clunking sounds. The easiest way to tell is to remove the serpentine belt and spin the water pump. It should turn smoothly and quietly. If it makes clunking sounds and feels kind of loose, it's no good. Quote
Stevo Posted July 7, 2004 Report Posted July 7, 2004 Usually a water pump on the go has a little drip before it ultimately fails. They seem to be made to do this. The free spinning test is a great idea though. Quote
Speckkial Posted July 9, 2004 Author Report Posted July 9, 2004 I got the water pump changed and the old one was leaking a bit. But the car still makes those damn sounds. Well whatever. Quote
GnatGoSplat Posted July 9, 2004 Report Posted July 9, 2004 When you say it sounds like it's dying, can you feel it too? Is the car trembling? Is the tach jumping up and down? Maybe it's not related to an engine accessory at all but ignition related. Quote
Speckkial Posted July 9, 2004 Author Report Posted July 9, 2004 I haven't noticed any extreme vibrations or feelings. But if it is ignition problem, what might be wrong? Quote
