90 lumina euro
new battery
when i use anything electrical in the car all the lights dimm and the voltage drops from 14 volts to 13.8 volts when the brakes are pushed and the rpms drop a little bit is this normal?
.2 volts? I wouldn't worry. A 'normal' charging system is supposed to run between 14-16 volts. These cars suck up electricity. I certainly wouldn't worry about .2 volts. If you want, check your alternator.
yea but for the rpms to drop and the lights to dimm is that ok
i put the battery in
Almost any auto parts store will do it for free. Check with an Auto Zone, Advance Auto Parts, or any CSK auto in the area. Yeah its normal for the RPM's to fluctuate. The engine is compensating for the increased load on the system. It should be a momentary fluctuation.
yea its just really annoying looking at the car in front of u at a light and when u hit the brakes seeing your lights dim on theyre bumper
Could very well be an alternator. Have 'er checked out soon.
IF you just put in a new battery did you make sure your contacts are clean?
yea i just wiped em off yesterday and no luck... i even moved my amp power wire to the aux batt post thinking it would help but nothing
i also have a problem on cold starts the car runs really rough and misfires ...then when warm only has a slight miss at idle..wasnt sure if its related or not
mine is bad and the check engine light comes on after driving long periods.
i never get a engine light and i passed emmisions without a prob i dont think its the egr
