need pinout from base to z34 (again)
hey guys long time no talk!
I ordered my speedhut guages anjd i need the pinout for the base to z34 conversion again, it was lost when i moved from my apt. If anyone can show me where it's at, or send me a link it would help a lot. Thanks in advance guys Jay
Oh the search didn't show up shit
Here ya go Jay!
For the Base Cluster
C3 - Pink/Black - Ignition Power
C4 - Yellow/Black - Low Coolant Light
C5 - Tan/White - Brake Light (parking brake or low brake fluid)
C6 - Brown -Charge Indicator
C7 - Dark Green - Coolant Temp Indicator
C9 - Black - Ground
C10 - Brn/Wht - SES Light
C11 - Tan/Blk - Shift Light
C12 - Lt Grn/Blk - Antilock light (if so equipped)
C13 - PPL - Fuel Level indicator
C16 - Lt Blue - Left Turn signal
D1 - tan - Oil Pressure Indicator
D2 - Yellow - Fasten Seat Belts Indicator
D8 - Gray - Dimmer switch
D12 - Black - Ground
D13 - Dk Grn - Speedometer
D15 - Dk Blue - Right turn signal
D16 - Lt Grn - High Beams
Ok, here is the pinout for the gages cluster.
C2 - Black - Ground
C3 - Gray - Dimmer
C5 - PPL - Fuel Level
C7 - Dk Grn - Coolant Temp
C9 - Lt Blue - Left Turn Signal
C11 - Yellow - Fasten Seat Belts Ind
C13 - Tan - Oil Pressure Indicator
C15 - Brn - Charge Indicator
C16 - Yel/Blk - Low Coolant
D1 - Dk Blue - RH Turn Signal
D2 - Lt Grn - High Beams
D3 - Tan/Blk - Shift Indicator
D4 - Pnk/Blk - Ignition Power
D5 - Dk Grn - Speedometer
D6 - Black - Ground
D9 - White - Tach Wire
D11 - Pink/Blk - Ignition Power
D13 - Tan/Wht - Brake indicator
D15 - Lt Grn/Blk - Antilock indicator
D16 - Brn/Wht - SES Light.
Wow, that was long, ok, for the two power wires, you have to choices, run a new lead from the fuse box to the second power lead, or run a jumper from one to the other. Which is what I did. As for the tach wire, you will need to get under the hood and unplug the left connector on the ICM. There are 5 wires in that connector. They are:
Tan/Blk - Bypass Wire for ECM
White - Tach signal for ECM
White - Tach signal for Instrument Cluster
PPL/Wht - Reference signal for ECM
Black/Rd - Ground from ICM to ECM.
You will need to splice into the white wire that is next to the purple wire. If you tap into the wrong one, it may cause the car to act up as the ECM won't know how fast the engine is running.
is that for the lumina?
:withstupid:
J/K yeah man thats what its for.
i recommend running the second power wire..... i didnt and my tach and speedo jump when using my turn signals.
how much did you pay for the guages? which ones are they the flame ones? what cluster do you have to have in order to get it, cause i gots a euro obviously.
my dash has the engine temp and oil pressure on the left, then speedo and tach, then fuel guage,is that the right setup to get one?
thanks guys! i have a z34 cluster same as the euro. I got the reverse glo and it is black face with blue font at night. I only got it with chevrolet lumina across the front. Thanks everyone! later Jay
Oh they were like $97 or $105 with the upgraded inverter.
I split the power for mine and have had zero problems.
