SmoothSteve3 Posted July 2, 2004 Report Posted July 2, 2004 Ok guys, after much debate and examination, I've determined that my only option is to upgrade to the 94+ rear brakes. Has anyone gotten the E-brake to work with this upgrade yet? If so, how..... Quote
GutlessSupreme Posted July 2, 2004 Report Posted July 2, 2004 http://home.comcast.net/~aldridgec/TGP/brakes/rear_brake_upgrade.htm Quote
Guest TurboSedan Posted July 2, 2004 Report Posted July 2, 2004 http://home.comcast.net/~aldridgec/TGP/brakes/rear_brake_upgrade.htm you don't have to modify (bend) the brake line/hose like it shows on Chris's page. i use completely different brake hoses (from the '95 Regal sedan donor car). it's ALL hose - not a hose with a pipe section on the end. here are mine: http://www.turbosedan.com/DSC00865.JPG my original '91 hoses would have worked better, i couldn't use them because they were trashed. the Regal hose works fine but the frame bracket on the end of the hose does not fit flush on the frame rail :? good luck with the E-brake. i have '95 Regal E-brake cables ready to go in, just need to get that bracket welded. no E-brake + manual transmission sux some people have gotten the '88-'93 E-brake cables to work, but from the pics i've seen it doesn't look very good. Quote
Baddflash Posted July 2, 2004 Report Posted July 2, 2004 Cool, thanks! I've been wanting to upgrade the rear brakes but with the 5-spd I have to have a working e-brake. I guess I can do it now. Quote
