syknesss Posted July 1, 2004 Report Share Posted July 1, 2004 all of the lights in my car dimm when i hit the brakes including the headlights its not really bad but its noticable....and my battery is not even 3 months old yet alt has been replaced be4 but i dont know how long ago Quote Link to comment Share on other sites More sharing options...
Garrett8 Posted July 1, 2004 Report Share Posted July 1, 2004 go to autozone and have them check the alternator Quote Link to comment Share on other sites More sharing options...
White93z34 Posted July 1, 2004 Report Share Posted July 1, 2004 my car did the exact thing when its alt was on its way out Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted July 1, 2004 Report Share Posted July 1, 2004 Check your connections at the alt and battery to see if they're tight. Also, check your grounds in the engine bay and clean any that are dirty/corroded. Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted July 1, 2004 Report Share Posted July 1, 2004 Check your connections at the alt and battery to see if they're tight. Also, check your grounds in the engine bay and clean any that are dirty/corroded. Â And have them check the battery as well. I've had nearly new batteries go bad. Quote Link to comment Share on other sites More sharing options...
syknesss Posted July 1, 2004 Author Report Share Posted July 1, 2004 could the alt be related to my cold start misfire ? Quote Link to comment Share on other sites More sharing options...
GP1138 Posted July 1, 2004 Report Share Posted July 1, 2004 could the alt be related to my cold start misfire ? Â I'd have the ICM and coilpacks checked. I noticed when my coilpacks needed replacing my alternator wouldn't charge properly. I also had that same problem before I replaced my alternator. Quote Link to comment Share on other sites More sharing options...
syknesss Posted July 1, 2004 Author Report Share Posted July 1, 2004 i have a icm and coils i just got from a yard i gonna swap them and see if it helps Quote Link to comment Share on other sites More sharing options...
Baddflash Posted July 1, 2004 Report Share Posted July 1, 2004 I had the same problem on my old Lum, I replaced the battery and the problem went away. It was last winter that this happened. Quote Link to comment Share on other sites More sharing options...
backinblack Posted July 8, 2004 Report Share Posted July 8, 2004 Check your negative battery cable. Especially the joint to the chassis under the battery tray. Quote Link to comment Share on other sites More sharing options...
jeremy Posted July 8, 2004 Report Share Posted July 8, 2004 update? Quote Link to comment Share on other sites More sharing options...
syknesss Posted July 9, 2004 Author Report Share Posted July 9, 2004 update is i bought a new car yesterday so if anyone wants to buy the car in my sig check the forsale board Quote Link to comment Share on other sites More sharing options...
