89Cutlass Posted December 11, 2002 Report Posted December 11, 2002 Ive got an 89 Olds Cutlass Supreme and want to hook up an aftermarket tach. Were do i hook it up to. I have 3 coil packs.. Thanks Craig Quote
GnatGoSplat Posted December 13, 2002 Report Posted December 13, 2002 There's a white wire coming out of the ignition module, that's the one you need to tap into. But a factory tach is way better looking and I'd recommend going that route. A 92-94 analog gauges cluster will plug right in with only minor wiring required (you might need to run the white wire from the module into the car to the cluster). Or an 88-91 digital gauges cluster can be installed but will required reorganizing some of the pins in the connector. Quote
RedZMonte Posted December 16, 2002 Report Posted December 16, 2002 Shawn is correct. on the ignition modual has a white wire on it.. my L67 had 2 white wires.. so if yours has 2 white wires on it then use a tap and a Fluke meter and the voltage should flucsuate with the RPM's. RedZ Quote
SuperBuick Posted December 16, 2002 Report Posted December 16, 2002 To tap into that wire do I just cut itand tap my wire into it? Won't that screw up the PCM once I cut it? Quote
GnatGoSplat Posted December 16, 2002 Report Posted December 16, 2002 I would just splice into it. Or if you can get a crimp terminal for the firewall connector, you could possibly just crimp your new wire to it and plug the terminal into the connector. The tach wire goes all the way to the firewall connector, but doesn't have a mating end inside the car. At least this is the case in my Cutlass, but on cars with full-digital clusters, you don't need the tach wire anyway. The digi tachs get their signal from the ALDL. Quote
89Cutlass Posted December 17, 2002 Author Report Posted December 17, 2002 Anyone no how I would go about finding a Full Digital Dash.. Quote
