will3.1 manifold fit 3100?
just what topic says. i need to find out if my 3.1 rear manifold will fit a 95 lumi 3100
if by "rear" you mean "lower", then no. If by "rear" you mean "upper" then no as well
generally speaking, no. You may want to enlarge the 3.1 manifold ports and make them D shaped (basically match the gaskets if you can) they physically bolt up.
Oh you'll also need to use the front, rear and crossover from the 3.1, not just the rear, should you want them to fit.
well i was just trying to see if one of my spares would fit one of my old teacher's lumi. i really don't want to go to a j/y and get him one cuz they charge an arm and a leg for shit around here. so...anyone got a 3100 rear manifold they want to sell?
My junkyard has em for $50. I had bought one for my moms car a few mos ago. Hers cracked, I imagine your teachers is cracked the same way especially if it's a '95-96 Lumina.
my junk yard has them for 50 too. and yep it's a 95 lumi. i was hoping someone would have one here cheaper before i ent to the j/y for it. either way it's better than the mechanic that told him 200 to fix the old one.
