mannix Posted June 29, 2004 Report Posted June 29, 2004 Didn't make it to emissions on saturday.... car tune-up (spark plugs, wires, oxygen sensor, oil, oil filter,replace battery, old one was completely dead), and now car sounds like it might have a miss. sounds like tss, tss, tss.... took spark plugs out to check if they were all firing, and the front middle one looks totally clean. could this be a bad injector,.... how to tell?? Quote
god910 Posted June 30, 2004 Report Posted June 30, 2004 Ohm it out. Unfortunetly. If you are magical you can check each bank, and see. (Use the search function, it's here somewhere) But I doubt it's an injector. They don't go bad very often. (See Jeff, now wasn't that optimistic?) Quote
Robby1870 Posted June 30, 2004 Report Posted June 30, 2004 yeah, injectors should be around 12 ohms impedence (or resistance, however you prefer 8) ) Quote
Jeff M Posted June 30, 2004 Report Posted June 30, 2004 Ohm it out. Unfortunetly. If you are magical you can check each bank, and see. (Use the search function, it's here somewhere) But I doubt it's an injector. They don't go bad very often. (See Jeff, now wasn't that optimistic?) Yo da man/god To be humble as well, I corrected my math on that post :oops: Jeff M Quote
