Chinski Posted December 11, 2002 Report Posted December 11, 2002 So I guess my left rear trailing arm is bent and possibly cracked. It doesn't look too hard to replae to me, but is there anything special that I have to do?. Should I get a replacement from a yard or where? Quote
Guest Posted December 11, 2002 Report Posted December 11, 2002 If you get it from a yard, then you run the risk of it being bent. It is a pain to take it off, and put it on seeing that they are torqued to a rediculously high number (over 100 ft.-lbs.). Just back the car up onto ramps, and use a strong ratchet with a pipe to get it off. and most importantly off all, be careful. Taylor Quote
GPRACER Posted December 11, 2002 Report Posted December 11, 2002 I recently replaced the left rear arm on my car, was less than 60 bucks at the dealer, I'd reccomend a new one. not a hard repair at all, wouldn't hurt o have a torque wrench and some specs.. Quote
Chinski Posted December 11, 2002 Author Report Posted December 11, 2002 Yeah this manual says 192 ft-lbs. Good thing I have a good torque wrench and a breaker bar. Quote
