Ok guys, I got some questions about engines..
Is the 3400 a rebored 3100?
Whats the difference between the 2000+ 3100 and the 94-99 3100?
Is the 3500 a 60 degree v6 and if so was it based off another 60?
And finally:
Will a 3.1L MPFI drop right into a Fiero with a 2.8L?
Thanks guys
Spencer
And finally:
Thanks guys
Spencer
1. Yes the 3400 has a bigger bore, but IIRC the block is slightly different because of the bigger bore.
2. The 2000+ 3100's got the 3400 heads which flow more air.
3. Yes, but I think it's an all new block.
4. Yes it should
Id hope it is.....but from what I saw, it looks exactly the same, Distributor o-ring and all :dammit:
And finally:
Thanks guys
Spencer
1. Yes, that is why alot of guys do the 3400 swap from their 3100s.
2. Gains in HP, 2000+ is like 170 and 94-99 is 160HP.
3. Not sure man, I don't know enuf about it engine. :?
4. Hell if a 3.4 can I'm sure a 3.1 can. :)
Can any of you show me a website that gives info about a 3400 swap? I'm heading to the J/Y tomorrow (mostly for a new hood and HUD, rust has gone through the whole front of it now), and maybe I can check about getting a 3400. Thanks
-Spencer
