Tools needed for '96 strut/knuckle swap?
Socket set, tierod/balljoint puller, pliers, hub puller, 36mm socket (to remove hub nut), and torque wrench.
If the balljoint boots are shot on the knuckles like mine were (due to having been removed by a pickle fork), you'll need an angle grinder or maybe a punch to replace them. If you pull your outer tierods using a pickle-fork puller, chances are, they will need to be replaced too.
Just use a BFH to remove them. It'll save you money, and you get to smash the shit outta stuff.
