1994 Cutlass Supreme convt top
I have been having trouble with the motor for my top. Can anyone recommend a starting point, troubleshooting techniques, etc? Thank you
is it not working at all? sometimes? slowly?
if it works but is hesitant or goes slowly, check the fluid in the pump.
that's probably one of the more common problems, as with both my cavalier and my cutlass. that's the main thing i can think of off hand
Thank you for the quick response and suggestion. It works sometimes and hesitates. Any particular way to check the fluid or special type of fluid to use?
here are a few quick snapshots i took
on the passenger side of the trunk, pull back the carpet and youll see the pump under the bracket thingy
theres a cap on the top that tightens (if i remember right) with some sort of star driver. make sure thats tight first, and/or take that off to add more fluid.
I'm pretty sure its just standard brake fluid. or at least thats what i remember using
thank you so much for the help. That makes perfect sense. I really do appreciate your time and help.
Can any other convertible owners or knowlegable souls weigh in on EXACTLY what type of fluid to put in the pump? And how do know if its full, I know that may sound stupid, but my pump isn't full up to the top and there's no markings to speak of.
The top reservoir takes Dexron III ATF, definitely NOT brake fluid.
Thanks guys, I would have looked it up myself, but I don't have a manual and the PDF copy I have doesn't cover the convertible. Any one know how full is full though???
Manual says: "Oil at upper line on reservoir with top in the down position. Oil at lower level reservior with top in the up position."
