test4echo Posted June 23, 2004 Report Posted June 23, 2004 Now that I have this really expensive Snap-on scanner to play with all summer Its an MTG2501, the whole kit. Where can I get the optimal values for each sensor on my 92 Z34 so I can compare actual values and optimal? I don't have a shop manual, but i am prepared to buy one if i have to. All i have is that crappy haynes manual. thanks, test Quote
Stevo Posted June 25, 2004 Report Posted June 25, 2004 I'm not sure what the GM guys use to scan codes with but I have seen some scanners not grab all codes on a system or even be able to pull codes stored over a long time. I'd rather the scanner the dealer has. I can only guess it's only available through them with their software for GM cars. The snap on one is not as specific, Jack of all trades and master of none type. Quote
4spdz34 Posted June 25, 2004 Report Posted June 25, 2004 the red brick eh? i hate that scanner it works for jack. teh dealer scanner u are talking about is the tech 2. i believe u can get it from otc but its a lil different then the dealer one. o and i think price is around 3k these days Quote
test4echo Posted June 25, 2004 Author Report Posted June 25, 2004 You guys seem not to like this model. Its made by Snap -On. Any particular reason? I have found it to be quite useful so far. The live graphics mode kicks ass. I didn't know this, but the live graphics mode DOES display not only real time data but a history of sensor operation along with the optimal or Normal values. I don't care, I don't have to pay a dime to use it this summer. I take what I can get. Your right, this model is just over 3K. I've already pinned down and found a vaccum leak using it. One of my MAP vaccums was lying against my EGR tube and ended up melting it closed. Everytime the tube got hot enough, it would re-melt the vaccum line. Still have a few other issues to take of though. Car still isn't 100%. test, Quote
