GnatGoSplat Posted June 23, 2004 Report Share Posted June 23, 2004 Has anyone removed their rear leaf spring and happened to take pics of the upper spring perch? Quote Link to comment Share on other sites More sharing options...
cryptnix Posted June 23, 2004 Report Share Posted June 23, 2004 can't say that i have ... i'm about to rid mine i want mine lowered PRONTO Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted June 23, 2004 Report Share Posted June 23, 2004 i have tomarrow off, i'll try to get a pic up then. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted June 24, 2004 Author Report Share Posted June 24, 2004 Thanks Josh, I'm looking forward to it. The rear of my car needs a drop BAD, especially after adding the ST springs to the front. I think I need to drop it almost 2-1/2" to match the front. :shock: Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted June 25, 2004 Report Share Posted June 25, 2004 hope this is what you're looking for: dang i need some new suspension bushings.... Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted June 25, 2004 Author Report Share Posted June 25, 2004 Thanks Joshua, that's exactly what I was looking for! Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted June 26, 2004 Report Share Posted June 26, 2004 pics should be back up soon (server backup) Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted June 26, 2004 Report Share Posted June 26, 2004 x x x x x x Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted June 26, 2004 Report Share Posted June 26, 2004 like i said. Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted June 28, 2004 Report Share Posted June 28, 2004 pics are back up nstuff. Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted July 2, 2004 Report Share Posted July 2, 2004 how is it possible to modify the upper spring perch to lower the car? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted July 2, 2004 Author Report Share Posted July 2, 2004 Well, immediately I can see there are 2 hollow blocks. I suppose those could be cut out. Inside the blocks I believe is some kind of threaded thing, like a big rectangular nut with 2 holes (I don't know what you would call that). So you could drill holes in the top of the axle subframe to match the holes in the spring, then put that threaded nut thing above the axle and mount the spring that way. The only problem comes with the curvature of the spring. If the spring is too curved between the 2 rubber inner bushings, then it would physically touch the upper axle if the 2 hollow metal blocks are removed. If the spring does NOT touch the upper axle, then I think you'd be golden. I'd have to take a better look at a spring to see how much curvature is between the 2 inner rubber bushings. That was just my theory, anyway. It does look like clearance would be VERY tight with those big transverse arm nuts and threads in the way. Quote Link to comment Share on other sites More sharing options...
