White93z34 Posted June 22, 2004 Report Posted June 22, 2004 is anyone running these tires i have the oppurtunity to get a almost brand new set of yokohamas for $200 from a friend, my only point of concern is that my car came with and still has 225/60/16 will the 55s make any difference i know they are abit smaller then mine will this make my speedo be innacurate? Quote
jeremy Posted June 22, 2004 Report Posted June 22, 2004 not enough for you to notice....factory speedos are normally are off by a few MPH anyway.... Quote
bluegp Posted June 22, 2004 Report Posted June 22, 2004 225/55/16 - is anyone running these tires...will this make my speedo be innacurate? That's the size I have. I like them because they look a lot wider than the 60 series. In my case, the '89 originally came with 195/70/15 tires (that size is not made anymore) and the 225/55/16 comes out to be the same diameter. There were a few different size tires used on the W's - I doubt there were any differences in the VSS, ECM, etc. between these cars. There's probably a "average" tire diameter that the parts are calibrated for. Like said, your speedo may be a little off anyway. If it is dead on right now, it will be a little off when those tires are used. Here's a speedometer error calculator: http://www.paspeedo.com/calculator.htm With the sizes mentioned, it says that when the speedo would read 55 MPH, the actual speed would be 53 MPH. Quote
BIGBULS Posted June 22, 2004 Report Posted June 22, 2004 It's ~3% difference............not that bad. I'd do it if you are a little strapped for cash. Quote
runt Posted June 23, 2004 Report Posted June 23, 2004 hell yeah do it. tires are expensive...lol Quote
Baddflash Posted June 23, 2004 Report Posted June 23, 2004 For sure get the tires, good deal! My car originally came with 195/75/14 but now has 225/60/16 buy those calculations it would read under by a few mph. LOL! I forgot I'm using the chip and ss from another car so I have no idea how far my speedo is off. Any idea what a '90 GP SE with 5-spd might have gotten for factory tires/rim size??? Quote
joey b Posted June 24, 2004 Report Posted June 24, 2004 I can get 3 like new yokos for 45 bucks, maybe 50 series though. What do you think about that and is there anyway to correct the speedo? Quote
