wiring is smoking HELP
Guest Anonymous
I had two sets of 2 small red LED's that i was wiirng into my car. they are 12v/ set.
Since i only had one outlet, i decided to splice one set into the other. I matched up all the wires and ground, taped everything up and plugged them in... well all the connections started smoking and the plug did too. So i disconnected everything and put the plugs back the way they were, and everything still smoked even with the normal amount of LED's per line. WTF is up with that? Luckily, i didnt blow a fuse and everything in the car works fine except the damn LED's...
Why would it do this even though i restored the LED's back the way they were, and is there any way to correct the problem?
dunno without seeing what you did.. My guess would be you crossed the wires on the plugs.
Guest Anonymous
after all is said and done, i have four good LED projectors and two fried plugs. Any way to wire them in with the headlights? each set of two pulls 12v.
