Whats wrong with my dash?
you guessed it, HUD! need to relocate the speakers to the doors, cut the driverside speaker mount on the dash out, and walaa! till i can get a hold of a HUD dashpad. the lumi pad needs a lil more cutting on one corner, and i need to think of a snazzy way to cover the remaining speaker hole(most likely use vinyl).
*note: where it looks like there is a section missing from the front of the pad, paper, the $20.00 digi needs brightness.*
i've never seen an hud setup in a lumi before, got anymore pics?
I hate to break it to ya since it looks like you already started cutting your dash pad BUT...
You've got the HUD on backwards!!! :shock:
i had it the other way, then cut it, then i turned it around and poped it in, and that corner didnt go in. looks like i originaly did it right :shock: good guess on my part :P now, whats the best way to "remove" the speaker mount attached to the 1 piece dash w/o having to take all that apart?
Speaker mount? Well, can't help you there because I don't know anything about Lumina dashes.
Another issue you might have is where the HUD will appear in the windshield. It looks like you put your HUD close to the front edge (closer to the windshield), but the Cutlass and GP HUD unit is actually closer to the back of the dash (closer to the driver). I think there is less than 1" between the edge and the HUD unit.
