Turbo related question
Hey all, I looked all over and I cant figure out what the purpose of a crossover pipe in a turbo application is. :x
Also, assuming I have a turbo for my LQ1 how much approxmately would materials cost for the project?
An itemized list would be nice.
thanks.
Guest Anonymous
The x-over gets the exhaust to the turbo.
For your 2nd question, do a search.
Guest TurboSedan
it probably wouldn't be a good idea to have a turbo fed exhaust gas from only one cylinder bank :wink: hence the need for a crossover pipe. V engines need a crossover pipe so that exhaust gas from both banks gets routed to the turbocharger, which would be mounted somewhere in the middle of the crossover pipe. here's my TGP crossover:
the only thing i found that was called a crossover in my ahlf hour or so search of the internet was an X shaped piece of pipe for improver sound quality through the exhaust.
And to turby: The reason for asking about the list was to get approxmiate prices for the various items required, I searched and found a list.
BTW your signature confused the hell out of me at first.
Hey all, I looked all over and I cant figure out what the purpose of a crossover pipe in a turbo application is. to balance the pressure of the turbo on the two banks of cylinders.
Also, assuming I have a turbo for my LQ1 how much approxmately would materials cost for the project? $1500
thanks.
I wanted a list of what parts would cost. eg
X-over $---
tubing $--- and so on.
Xover
Down pipe
BOV
Turbo
Fuel Pump
Mini afc and or FMU
Intercooler(not needed but HIGHLY reccomended)
Oil feed and return lines
Boost Gauge
Alot of misc small parts
Piping for Turbo-IC-Plenum
Possibly some fuel injectors
Thats a start, im sure I am forgeting some things.
Guest TurboSedan
X-over $---
almost impossible to give even an estimate of what it could cost. at least with an LQ1 you can use a front exhaust manifold on the rear, but you'll need to have about everything else custom made. hopefully you can do the work yourself or know people that can do it. i think brian89gp, RedZMonte, and timg are the only ones here that have a custom turbo 3.4 DOHC. good luck
