89Cutlass Posted December 9, 2002 Report Posted December 9, 2002 K ive always had this weird high idle problem. the engine runs smooth and dosnt missfire at all. and i a checked all the vacume lines and gaskets i can think off and cant find any leaks. the only way i can get it to kick down the idle is to put the car in neutral and roll backwards for a sec then it will kick down to normal but sometimes even if i rev it up it will kick the idle back up. ANY IDEAS ANYONE ?? thanks Craig 1989 OLDS CUTLASS SUPREME 2.8L Quote
BlackSunshine Posted December 17, 2002 Report Posted December 17, 2002 Well, we seemed to have solved the problem. After heavily cleaning the throttle body and changing the wires and hooking back up your temp sensor she purrs like all your cats. So if anyone else has these symptoms, try that. Quote
