dohc v6 Posted June 14, 2004 Report Posted June 14, 2004 what id included in the swap. i have everything need as far a tranny,clutch,cables. all i need is shifter and pedals. what is included in the wiring Quote
Baddflash Posted June 14, 2004 Report Posted June 14, 2004 This is my parts list for the 282 swap which shouldn't be much different. You should try searching though as this has been discussed a lot recently. - Getrag 282 - Transmission mount - Shift cable mount - Intermediate shaft to engine mount - Clutch master/slave cylinder assy. - Clutch inspection cover - Connectors/wire lead for speed sensor and backup lights OR - 5-speed engine wiring harness - Throttle body plug from 5-speed v6 gm 86-93 (auto vacuum line plug) - 5-speed drive shafts that work with you brakes (ABS or NON-ABS) - 5-speed ECM MEMCAL - 5-speed flywheel - Clutch, TO bearing - GM Syncromesh 3L - Shifter assy. W/cables and firewall seal. - Clutch and brake pedal - Clutch switch (allows starter to engage) - Clutch cruise control switch (if you have cruise) There may be other parts needed depending on the vehicle you start with, if you’re car is column shifted it’s going to be a bit more work. You will need to cut your carpet, add a console and at least a drivers seat (in a pinch the pass. front seat will fit in the drivers spot). For looks you should swap the steering column as well. I'm not sure what year car you have but if you're 94+ you're going to have to swap the pedal pan which is a fair amount of work. Quote
dohc v6 Posted June 14, 2004 Author Report Posted June 14, 2004 i have everything because wew are rebuilding a 92 5 speed and are replacing everything on it so i have the old parts that are still in good working condition. i just need help on the wiring and everthing else should be easy. Quote
