Tru2Chevy Posted June 9, 2004 Report Share Posted June 9, 2004 Does anyone know part numbers for poly dogbone bushings to replace the busted rubber ones in my '91 Lumina 3.1? I really don't want to spend $130 on the FFPs just because they are shiny and bit lighter and stiffer. - Justin Quote Link to comment Share on other sites More sharing options...
Tru2Chevy Posted June 13, 2004 Author Report Share Posted June 13, 2004 TTT....anyone? - Justin Quote Link to comment Share on other sites More sharing options...
scorpion_x9 Posted June 13, 2004 Report Share Posted June 13, 2004 I don't know any part numbers, but try visiting these sites. http://www.autozone.com - They carry Anchor junk. http://www.partsamreica.com - I believe they carry Anchor junk as well. http://www.napaonline.com - I believe the also carry Anchor junk as well. You could try them, but my friend got anchor dog bones and they were just as bad as the old ones. If you want good ones, go with the stock GM part. I have no clue as to how much they are though but I think they are going to be about as much and the FFP dog bones. Quote Link to comment Share on other sites More sharing options...
R Dubya Posted June 14, 2004 Report Share Posted June 14, 2004 Ok, here's the part number for Energy Suspension poly bushings. These work well and make a considerable difference in engine movement, but you may notice a noisier ride (not really). One set does one side of two dogbones, or 2 sets do both engine and frame side. I did the engine side and it made a nice difference. You will need a 1 3/4 inch holesaw to hollow out the old bushings, and the polys fit right in. Good luck. Try to find someone with a drill press it's easier. PN # 3.7103G Quote Link to comment Share on other sites More sharing options...
Tru2Chevy Posted June 14, 2004 Author Report Share Posted June 14, 2004 scorpion_x9 - Thanks, but I want to upgrade to poly bushings, not use factory rubber. RW89TGP - Thanks for the part #. I actually found a good deal on slightly used FFP's, but I'll make a note of the part number for future referance. My buddy's dad works in a machine shop, so he has a bushing press that he uses to do bushings for our Camaro's...much easier than drilling them out - Justin Quote Link to comment Share on other sites More sharing options...
