life hates me !!!! :( on my new GTP too
i was just driving to lunch at work today, took a right turn, and heard it.
Wasnt to bad, but I had to drive it home. Stopped at a garage cause by the time i got home, i could barely do 20mph.
Any ideas what it is/how much to fix and shit?
This sucks, I JUST GOT THIS CAR :( :( :( :cry:
John
Guest TurboSedan
John
looks to me like you need a new front sway bar...
well i told you before, WELD IT, its cheaper and should work...
makes sure its primed and painted afterwards to prevent rust...
Guest TurboSedan
:shock:
Yeah...um, no. Get the GMPP kit for 120 and upgrade everything. Why polish a turd by welding the stock POS that broke in the first place?
I can't get the link to work (DNS Error), but if it's a broken sway bar, I don't think it's a good idea to weld it. Aren't those things made of spring steel?
I would just buy a new one. I don't know about 97+, but they're not a huge deal to swap out on a gen 1.
just so he can drive it again, also, could prolly weld it back togeather for 10$
so thats a better idea then spending 110 unneccesary dollars...
also, its like welding a shock mount back togeather, just make sure that you get some-body good to do it so it doesn't go out of alignment (even though i'm not completely sure how that could happen.
ALSO a weld should hold longer then any other part of the sway bar, if you guys know anything about welding, you guys should know that a good weld should hold better then the steel next to it...
as i said WELD IT
also keep in mind a sway bar is just for stiffer handling. the clunking was most likely caused by the bar hitting the part that broke off when the a-arm moved up and down.
shawn, the pics work now if you wanna see what im talking about
:cry: :cry: :cry:
My mechanic said he has never seen a sway bar do that. EVER!
Guess its weird eh?
John
theres a reason they make bushings and stuff for suspension, so why on earth would you weld it? Suspension parts need to give a little for the car to ride/act like a car should. I know....lets go weld the motor and trans to the subframe, that'll make it stronger :roll:
temorary....
so if your done flaming then leave it alone...
Guest TurboSedan
do it the right way and just replace it. this is no place for welding.
Agree
