whiteSE Posted June 6, 2004 Report Posted June 6, 2004 When you release the parking brake, the light doesn't go out. As far as I can tell the brake is actually off. Knowing that, I thought I would just disconnect the electrical contact point just to make the dash light go off and stay off. That didn't work. Is there a second electrical connection at the rear that tells the front that the brake may still partially be engaged?? I am stumped. Phil. Quote
Gearhead43 Posted June 7, 2004 Report Posted June 7, 2004 Phil, My wife's GP does this from time to time. The contact might be sticking. Take your hand and pull foward on the parking brake pedal. That should be enough to turn off the dash light. Quote
DaveFromColorado Posted June 7, 2004 Report Posted June 7, 2004 .. if you're low on brake fluid, that can do it too. --Dave Quote
Nick1234 Posted June 8, 2004 Report Posted June 8, 2004 try checking the fuses on the driver side of the car under the hood. i know when you pull one of those block fuses, it leaves the parking break light on. does your car have abs? Quote
digitaloutsider Posted June 8, 2004 Report Posted June 8, 2004 I'd check the brake fluid first, since that's by far the most obvious. Quote
ismellrealbad Posted June 9, 2004 Report Posted June 9, 2004 the brake light being on means theres something wrong with the brakes. mine goes on and off and i already asked what it could be but nobody answered :? it happened after my dad replaced the front calipers for me, but we put them on backwards originally. now they are on correctly and the light still wont go out. brakes have been bled countless times, even more odd is the brakes work fine and the light goes on and off randomly Quote
whiteSE Posted June 10, 2004 Author Report Posted June 10, 2004 Thanks all I will try it out later this week - it's just too damn hot outside!!! 8) I did just change the brakes so maybe..... low brake fluid would make it stay on too??? I thought there were 2 different lights, 1 for parking brake and 1 for regular brakes.....I actually better check that brake fluid level as I haven't since just before I changed the brakes.. whoah...I am scared now I will definetly check the fluid in the morning. Phil Quote
