90lumina3.1 Posted December 8, 2002 Report Posted December 8, 2002 im getting smoke from my rotors, and i just changed the brake pads. its odd smelling, and is worrying me. the brakes seem to fade alot while going down a hill or at around 50-60mph. somebody please helpme! thanks in advance Quote
Guest Anonymous Posted December 8, 2002 Report Posted December 8, 2002 Is it the rear brakes? If it is your caliper slides are probably froze up causing the pads to rub when the brakes aren't being used. Does your car seem to slow down faster than normal when you let off the gas? Quote
90lumina3.1 Posted December 8, 2002 Author Report Posted December 8, 2002 oops.. forgot to add it was the front brakes. the rear ones have one new caliper, one old, replaced last year Quote
Brian P Posted December 8, 2002 Report Posted December 8, 2002 it's absolutely normal for the pads to smoke initially after install. It's the transfer of resins onto the rotor. There's a great article at http://www.60degreev6.com "The burnish procedure is the last most critical item. It provides the one to one ratio of resin transfer under controlled procedure for optimum brake performance. (This is NOT a BURN IN by any means. A burn in will degrade the system severely) Burnish rules: One mile brake cool down at 55 MPH between procedures/controlled stops. Burnish runs are: 1st stop from 45 MPH is a moderate deceleration. The next 5 to 7 stops, from 60 MPH, are a near panic stop. (Actually, a accelerometer should be used for decel rates). A one mile cool down is mandatory between stops. At the end the brake pedal will start having a mushy feel. It is common for the driver to smell and see smoke from the wheels. This transfers the resin from the brake pads/shoes to the rotors/drums. You must allow a TWO hour cool down of the system. If the ambient temperature is higher than 75 degrees F, I usually allow three to four hour cool downs. The longer the better. Instruct the owner to try not to panic stop the vehicle for 200 miles. (The only complaint I have ever received from anyone is that the brakes are allot more sensitive than ever." Quote
90lumina3.1 Posted December 9, 2002 Author Report Posted December 9, 2002 wow, whered you find that? i was looking all over their site trying to find something, but i couldnt find anything at all. Quote
chronic139 Posted December 11, 2002 Report Posted December 11, 2002 make sure you dont have a brake fluid leak bro. The pedal fade could be a loss of pressure from fluid pissing out. Quote
90lumina3.1 Posted December 11, 2002 Author Report Posted December 11, 2002 i cant seem to figure out why brake fluid is flowing back out of my resiviour either! Quote
J Posted December 11, 2002 Report Posted December 11, 2002 I made my rotors turn blue on my old 1990 sunchicken convertible. I didn't use the bench grinder with the wire brush attachment to clean the slides and no lube and guess what you get? Glazed pads and Rotors, oh man that was a nasty smell. But i was sellin it ne way, lubed it up like a whore and sold that bitch. Hope everythign works out for ya. Later Jay Quote
90lumina3.1 Posted December 11, 2002 Author Report Posted December 11, 2002 i figured it out... good ol brakleen works wonders. musta had oil or somethin on there. Quote
