Invasion1
I can't think of anything else you'll need offhand, when I installed it I had the same stuff you have right now. Once you understand what each wire does/ needs then the wiring is pretty straightforward.
if you look on the face of the plugs (climate control side) they're numbered. 1st pin starts at 7 and last is 15. The ground I listed as "1" must have been a typo. I'll see if I can find my list on paper that shows that ground location, but it shouldnt be hard to distinguish the black wire(s) anyway.
notice there's no pins 1-6 (ignore that ground location #1, thats a typo). GM didn't label the pins 1-9....they labeled them 7-15. So the first pin on the left is #7, 2nd pin is #8, etc. You'll see #7 and #15 stamped into the plastic on the face of the plugs (the climate control side)
in the case of C2-14 that is connector 2 (grey) and the 14th location????
It's basically like this: The pins are labeled:
left to right: * * * * * * * * *
GM's #'s:.... 7 8 9 10 11 12 13 14 15
this is per-plug. All 3 are numbered this way.
