z34_nut Posted June 2, 2004 Report Posted June 2, 2004 i need to knwo this so i know what you guys did with the dimmer switch, personally i have the trigger flopping around on the lense, but i want make it has a clean look, or is there a way to hard wire the dimmer into the dash dimmer? any help? Quote
john99gtp Posted June 2, 2004 Report Posted June 2, 2004 i need to knwo this so i know what you guys did with the dimmer switch, personally i have the trigger flopping around on the lense, but i want make it has a clean look, or is there a way to hard wire the dimmer into the dash dimmer? any help? i cant help, but wheres the pics? Can you stick that thing under the dash maybe? No wait, nm, wires (derr) Next to the headlight switch? Anyways, pics John Have fun with those, not like I could of used them anymore Quote
z34_nut Posted June 2, 2004 Author Report Posted June 2, 2004 naw it wouldn't work next to the headlight switch, but i think i found a position in which the switch can rest. personally i would like to eliminate the switch tho, like hardwire it into the dimmer on the dash, does any-one have a wiring diagram for the dimmer switch and where it leads to? Quote
Lumina_z34 Posted June 7, 2004 Report Posted June 7, 2004 i always just had the switch hanging to the left of the steering wheel below the gauge cluster. Quote
matts93z34 Posted June 7, 2004 Report Posted June 7, 2004 This is the way i ran mine. When i removed the gauge cluster i noticed a hole that went all the way down to under the dash. I ran the wire through this hole, By doing this you dont see the wire. Then i just used two screws and mounted it there so it doesnt just hang there. If you dont see it look where the parking brake is and look up. http://images.cardomain.com/member_images/8/web/380000-380999/380486_32_full.jpg Quote
